[GRASS-dev] [GRASS GIS] #626: layers re-renamed after change
properties (wxpython)
trac at osgeo.org
Wed Jun 3 18:55:27 EDT 2009
#626: layers re-renamed after change properties (wxpython)
Reporter: cnielsen | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
In wxpython if you rename a layer (not with g.rename but with right-
click->rename) and then you change the properties, after closing
properties the name returns to the actual filename (eg.
archsites at PERMANENT).
Ticket URL: <http://trac.osgeo.org/grass/ticket/626>
