[GRASS-dev] [GRASS GIS] #628: wingrass native: vdigit error on new
map
trac at osgeo.org
Thu Jun 4 04:49:27 EDT 2009
#628: wingrass native: vdigit error on new map
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Keywords: wingrass, vdigit | Platform: MSWindows XP
Cpu: x86-32 |
with the latest wingrass native stand-alone installer (6.4.0rc.svn.37703),
if you start the wxGui, in the map display window pull down 2D view to be
Digitize (hey, it built!), then on the left pull down the empty box to
select New vector map, add a name like "testmap" and press Ok you get an
error in the Output tab:
New vector map <testmap at user1> created
File
"C:\GRASS-6-SVN\etc\wxpython\gui_modules\toolbars.py", line
1071, in OnSelectMap
self.StartEditing(self.layers[selection])
File
1103, in StartEditing
self.parent.digit = Digit(mapwindow=self.parent.MapWindow)
File "C:\GRASS-6-SVN\etc\wxpython\gui_modules\vdigit.py",
line 685, in __init__
VDigit.__init__(self, mapwindow)
line 223, in __init__
mapwindow)
File
"C:/GRASS-6-SVN\etc\wxpython\vdigit\grass6_wxvdigit.py",
line 327, in __init__
this = _grass6_wxvdigit.new_Digit(*args)
TypeError
in method 'new_Digit', argument 2 of type 'wxWindow *'
File
1063, in OnSelectMap
if self.layers[selection] == self.mapLayer:
IndexError
list index out of range
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/628>
