[GRASS-dev] Nearest neighbour
andrea antonello
andrea.antonello at gmail.com
Fri Jun 5 19:48:00 EDT 2009
Hi Francesco,
> I noted that both r.proj/r.proj.seg use floor() in the NN method
> (at least in 6.4). Should not be a proper rounding to the nearest integer
> more appropriate?
glad you raise the question. I found the same methodology in the java
NN methods and was right these days I was wondering. The docs say it
is due to performance issues. Not sure if it is the same here.
Very interested here,
Regards,
Andrea
> Francesco P. Lovergine
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
