[GRASS-dev] [GRASS GIS] #629: WinGRASS: spaces in pathnames
GRASS GIS trac at osgeo.org
Sat Jun 6 08:54:02 EDT 2009
 Reporter:  hamish          |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect          |      Status:  new
 Priority:  normal          |   Milestone:  6.4.0
Component:  Installation    |     Version:  6.4.0 RCs
 Keywords:  wingrass, msys  |    Platform:  MSWindows XP
      Cpu:  x86-32          |
 trying the native stand-alone installer (rev37703) installed in
 C:\Program Files\GRASS GIS\GRASS-6-SVN to expose/fix some missing quoting.
 The icon to start the wxPython GUI directly works, but the Cmd> prompt
 fails for `v.db.select roads where="label ~ 'highway'"` with:
 Bad file descriptor: Files/GRASS
 The "GRASS with MSYS" icon doesn't get very far at all due to msys bugs:
 in msys.bat :startrxvt section the line
 if NOT EXIST %WD%rxvt.exe goto startsh
 needs to have %WD%rxvt.exe "quoted" otherwise you get this error in the
 terminal window: (but it continues anyway)
 The system cannot find the path specified.
 a few lines later in `if NOT "x%*" == "x" start %WD%rxvt -backspacekey ...
 -e /bin/sh --login -c "%*"` it fails with a pop up window:
 Windows cannot find 'C:\Program'. Make sure you typed the name correctly,
 if you "quote" %WD%rxvt it then gives the error that it can not find the
 program `-backspacekey, Make sure that you typed the name correctly, ...`.
 maybe using a newer msys package helps fix these?
 if not, time to report some bugs to them.
 also, the grass dirname in msys/etc/fstab needs to be quoted?
 (do that in mswindows/GRASS-Installer.nsi)
 knock these things off one by one...
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/629>
