[GRASS-dev] Python SWIG
Glynn Clements
glynn at gclements.plus.com
Sat Jun 6 13:52:20 EDT 2009
chris carleton wrote:
> I've read somewhere (by Glenn, I think) that Python-SWIG might not
> go much farther with GRASS due to some limitations of the SWIG
> interface (I'm not expert enough to know either way). Despite that,
> I can't see another way to program what I want to do with GRASS. So,
> I was hoping that someone on the list has a full list of currently
> wrapped GRASS functions so that I know what I have to work with so
> far.
Everything in the following headers has been wrapped:
G3d.h
P_datetime.h
Vect.h
arraystats.h
cluster.h
datetime.h
dbmi.h
display.h
gis.h
gisdefs.h
gmath.h
gprojects.h
imagedefs.h
imagery.h
raster.h
stats.h
transform.h
vect/dig_defines.h
vect/dig_structs.h
vedit.h
However, some of those wrappers will be unusable because of an
inability to pass an argument from Python or return the result to
Python.
> Fortunately, I can just use Python scripting in the module when
> I don't have direct access to GRASS functions, although that's going
> to slow it all down.
> The other question I have is related to raster editing. I need to be
> able to edit specific cells in a raster map based on coordinate
> locations passed to the editing function (I can sort of see how to
> do it using the buffers that hold the row of raster data), but I
> don't want a whole new map generated every time an edit is made. Is
> it possible to edit a cell and then just close the map without
> re-writing the whole matrix?
Rasters cannot be modified "in place".
> Also, if I'm making say a thousand
> calls to that function will there be a noticeable lag time because
> of all the opening and closing of the raster map (i.e. how much time
> does it take to open and close a raster for reading/editing?).
Modifying rasters one cell at a time isn't practical.
One practical option is the mechanism which d.rast.edit uses:
individual changes are stored internally; the map is updated by
exporting the changes to a raster map using r.in.ascii, then the
changes are merged with the original map using r.patch.
