[GRASS-dev] Re: [GRASS GIS] #629: WinGRASS: spaces in pathnames
trac at osgeo.org
Sat Jun 6 17:45:25 EDT 2009
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Installation | Version: 6.4.0 RCs
Resolution: | Keywords: wingrass, msys
Platform: MSWindows XP | Cpu: x86-32
Comment (by hamish):
> Replying to [ticket:629 hamish]:
> > The icon to start the wxPython GUI directly works, but the
> > Cmd> prompt fails for
> > `v.db.select roads where="label ~ 'highway'"` with:
Bad file descriptor: Files/GRASS
Replying to [comment:4 glynn]:
> This one isn't an MSys issue, as MSys shouldn't be involved in
> running the wxPython GUI, or in running commands from it.
> Did the shlex fix make it into the version which you're testing?
yes.
I also notice that error after fixes to msys.bat I start grass + msys
terminal from C:\Program Files\GRASS GIS\...
looking trough "`set`" I don't see anything obviously broken.
running `v.db.select roads` from the msys command line with DEBUG=5 it
shows that it gets up to
D2/5: opendir c:/Program Files/GRASS GIS/GRASS-6-SVN\driver\db\
(slash directions verbatim)
then it locks up the msys terminal.
that debug message comes from lib/db/dbmi_base/dbmscap.c
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/629#comment:5>
