[GRASS-dev] Re: [GRASS GIS] #73: r.out.gdal tiff output does not
work
trac at osgeo.org
Sat Jun 6 18:32:38 EDT 2009
#73: r.out.gdal tiff output does not work
Reporter: helena | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.5.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.out.gdal, tiff
Platform: All | Cpu: All
Comment (by hamish):
Replying to [comment:49 mmetz]:
> - NaN for all GDAL floating point datatypes. Is NaN
> constructed with 0.0/0.0 ok?
yes (AFAIK)
> - GDAL signed int types: first try minimum in potential range, if
raster_min <= type_min, try maximum in potential range, if raster_max >=
type_max, use minimum (would be (GInt32) 0x80000000 for GDT_Int32). This
can re-use results of range check above.
> - GDAL unsigned int types: first try maximum in potential range, if
raster_max >= type_max, try minimum in potential range, if raster_min <=
type_min, use maximum. This can re-use results of range check above.
it all seems a bit complicated, but ok.
> * before actual export, in case of custom nodata make sure the metadata
nodata value and the raster nodata value are identical
why? if custom nodata then export NULLs in the map to be the custom value
and clobber any real data which had that value.
(perhaps I don't understand something here..)
> - if (nodata != (double) (GDAL datatype) nodata) -> warning and
nodata = (double) (GDAL datatype) nodata
if the user asks to use a certain nodata value and it is illegal for the
data type then exit with an error, probably giving the available range in
the error message. don't automagically correct it for them and continue
(ie override their expressed wishes). It is a recipe for pain.
> - if there are cells == nodata value and NULL cells were assigned
that nodata value -> -f flag and user nodata value: warning, else error
ok
> Hamish, what exactly should this compatibility flag do? There
> is all sorts of software with all sorts of different
> deficiencies out there...
umm, I forget what that was in reference to. ??minimalistic metadata
output??
is everyone happy with the colortable export stuff now?
(my only issue with it is that if you pass the no-metadata create
option to GDAL, GRASS adds its stuff anyway)
I shifted the bug target to 6.5 as this needs testing before going into
6.4.0 (this is a substantial last-minute change to a core module & we
can't keep on resetting the RC cycle + we seem to have survived with it
as-was for this long...). Strong candidate for 6.4.1.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/73#comment:52>
