[GRASS-dev] Re: [GRASS GIS] #636: r.thin creates triangle at acute intersection of two lines
GRASS GIS trac at osgeo.org
Wed Jun 10 23:33:32 EDT 2009
  Reporter:  needelsd  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  normal    |   Milestone:  6.4.0
 Component:  Raster    |     Version:  6.4.0 RCs
Resolution:            |    Keywords:  r.thin, r.to.vect
  Platform:  MacOSX    |         Cpu:  OSX/Intel
Changes (by hamish):
  * keywords:  r.thin => r.thin, r.to.vect
Comment:
 I think this is really a r.to.vect issue and not a r.thin one.
 I am not sure if there is a correct solution though. i.e. this could be a
 (desired in some cases) feature, not a bug.
 to remove the undangles maybe v.to.db upload line length then v.extract
 where line length > some threshold?
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/636#comment:1>
