[GRASS-dev] Re: [GRASS GIS] #637: Problems with paths in the TCL/TK Windows GUI
GRASS GIS trac at osgeo.org
Thu Jun 11 07:02:44 EDT 2009
  Reporter:  marmai        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  critical      |   Milestone:  6.4.0
 Component:  Tcl           |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  Tcl Window Gui path, wingrass
  Platform:  MSWindows 2K  |         Cpu:  Unspecified
Changes (by hamish):
  * keywords:  Tcl Window Gui path => Tcl Window Gui path, wingrass
  * priority:  normal => critical
Comment:
 Replying to [ticket:637 marmai]:
 > Within the tcltk-GUI it is not possible to select a map within
 > the project:
 > When clicking 'Add vector layer', then on the icon in the lower
 > part of the GIS Manager (tcltk-GUI) 'vector map to display'.
 > Within the following pop-up window there are no maps listed.
 > With the 'g.list type=vect' command entered in the GIS.m window,
 > all vector maps are listed as expected. And it is also possible
 > to show the maps by entering the names of the maps in the
 > 'Vector map'- field in the lower part of the GIS Manager.
 > Just selecting with the icon is not possible.
 confirmed with the latest wingrass installer (Colin's stand alone version
 is much newer than the current osgeo4w build)
 this is a close relative of bug #593.
 > Furthermore another path related problem with the tcltk-GUI:
 > Using the 'Show attribute data' button within the 'GIS Manager'
 > window the following command is sent to be executed:
 > db.select table=veg_buffer_1_dissolve
 database=D:\daten\GISDataBase/demolocation/PERMANENT/dbf/ driver=dbf
 > For this command I get the following error in the output:
 >  BMI-DBF driver error:
 >  Cannot create dbf database:
 >  D:datenGISDataBase/demolocation/PERMANENT/dbf/
 >  Unable to open database
 >  <D:datenGISDataBase/demolocation/PERMANENT/dbf/>
 > Notice: the \ are gone!
 > By correcting the command manually (backslash to slash) to:
 database=D:/daten/GISDataBase/demolocation/PERMANENT/dbf/ driver=dbf
 everything works fine.
 this is slightly different, but probably a close relative of error seen in
 https://trac.osgeo.org/grass/ticket/629#comment:5
 > All was tested with the GRASS6.4.0RC3 and GRASS6.4svn-2
 > (OSGeo4W installer)
 please could you try with the latest stand-alone installer?
 a lot has been fixed there.
 (you can have both installed without conflicts)
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/637#comment:1>
