[GRASS-dev] Re: [GRASS GIS] #629: WinGRASS: spaces in pathnames
trac at osgeo.org
Thu Jun 11 11:22:06 EDT 2009
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Installation | Version: 6.4.0 RCs
Resolution: | Keywords: wingrass, msys
Platform: MSWindows XP | Cpu: x86-32
Comment (by hamish):
attached is a patch against the latest CVS version of msys.bat which fixes
some of the quoting issues. You'll have to `rem` out the "abort if spaces
in pathname" if you want to allow that.
Colin re. fstab: as with %WD% in the patch, maybe you can use %~dps0 to
get the 8.3 shortname string somehow?
http://www.robvanderwoude.com/ntfor.php
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/629#comment:10>
