[GRASS-dev] Re: [GRASS GIS] #536: memory corruption in vector modules
GRASS GIS trac at osgeo.org
Thu Jun 11 12:56:08 EDT 2009
  Reporter:  martinl  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  reopened
  Priority:  blocker  |   Milestone:  7.0.0
 Component:  Vector   |     Version:  svn-trunk
Resolution:           |    Keywords:
  Platform:  Linux    |         Cpu:  x86-32
Comment (by mmetz):
 Martin, are you still observing memory corruption in vector modules in
 grass7?
 If yes, is your system 32 bit or 64 bit? If 32 bit, does memory corruption
 disappear when configuring without --enable-largefile?
 This memory corruption may have something to do with the new LFS support
 for vector libs, then I could have an idea how to fix it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/536#comment:22>
