[GRASS-dev] Re: [GRASS GIS] #629: WinGRASS: spaces in pathnames
trac at osgeo.org
Thu Jun 11 17:59:39 EDT 2009
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Installation | Version: 6.4.0 RCs
Resolution: | Keywords: wingrass, msys
Platform: MSWindows XP | Cpu: x86-32
Comment (by cnielsen):
Replying to [comment:10 hamish]:
> attached is a patch against the latest CVS version of msys.bat which
fixes some of the quoting issues. You'll have to `rem` out the "abort if
spaces in pathname" if you want to allow that.
As written it seems to abort whether there are spaces in the pathname or
not, I just tried it in c:\program files\ and c:\programs\ with the same
result. I think I've fixed it, see attached file (I've just attached
msys.bat not a patch. I could figure out svn diff for the CVS of
msys.bat...).
There's two bugs, one was your typo (hamish), the other I think is a bug
in the original msys.bat. Anyway, it successfully converts the path to 8.3
format.
Replying to [comment:8 hamish]:
> Replying to [comment:7 cnielsen]:
> > and allows the grass with msys shortcuts to
> > be executed with {{{msys.bat /grass/bin/grass64 -wxpython}}}
> > etc.
> I don't really understand that.
> Colin re. fstab: as with %WD% in the patch, maybe you can use %~dps0 to
get the 8.3 shortname string somehow?
http://www.robvanderwoude.com/ntfor.php
fstab is only needed for the "Grass with msys" shortcuts to work. They
work by calling msys.bat with the argument /grass/bin/grass64 -wxpython
(see the attached msys.bat lines 97 & 98. To fix this for spaces we have
two options though I'm not sure which will work.
1) fstab is written by the installer script with the install path, but I
can't find a way to get the nsi script to convert the path with %~dps0
before writing the fstab file.
2) If we can get msys.bat to convert a windows path (from an argument)
from (eg):
{{{ c:\Program Files\Grass\bin\grass64 -wxpython}}}
to:
{{{ /c/Program\ Files/Grass/bin/grass64 -wxpython }}}
then we wouldn't need fstab at all. The shortcut would use the windows
style path, and msys.bat would convert it into readable format for
msys.bat line 98
Ticket URL: <https://trac.osgeo.org/grass/ticket/629#comment:12>
