[GRASS-dev] Re: compilation error
Tim Michelsen
timmichelsen at gmx-topmail.de
Fri Jun 12 08:03:18 EDT 2009
> ERROR: Incompatible library version for module. You need to rebuild GRASS
> or untangle multiple installations.
> make[2]: *** [db.tables.tmp.html] Fehler 1
After Hamish recommended
make distclean
I got a litle further.
Now the next break:
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:23:29:
Fehler: ogr_srs_api.h: No such file or directory
In file included from proj_wrap.c:2694:
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:84:
Fehler: expected »=«, »,«, »;«, »asm« or »__attribute__« before
»GPJ_grass_to_osr«
/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:88:
Fehler: expected declaration specifiers or »...« before
»OGRSpatialReferenceH«
make[3]: *** [OBJ.i686-pc-linux-gnu/proj_wrap.o] Fehler 1
What does this mean?
Kind regards,
Timmie
