[GRASS-dev] Re: [GRASS GIS] #630: "Mapset Access" broken (wxpython)
trac at osgeo.org
Sun Jun 14 13:52:02 EDT 2009
Reporter: cnielsen | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords:
Platform: All | Cpu: Unspecified
Changes (by kyngchaos):
* platform: MSWindows XP => All
Comment:
On Jun 14, 2009, at 12:08 PM, Cline, Royce L. wrote:
On OS X with 6.4RC4 and RC5 when using Config->GIS Working
Environment->Mapset Access I get the following error:
Sun Jun 14 11:29:28 2009) Command finished (0 sec)
File
"/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpyt
hon/wxgui.py", line
366, in OnMapsets
dlg = preferences.MapsetAccess(parent=self,
id=wx.ID_ANY)
File
hon/gui_modules/prefer
ences.py", line 1732, in __init__
self.mapsetlb.LoadData(self.all_mapsets)
File
ences.py", line 1811, in LoadData
stat_info =
os.stat(mapsetPath)
OSError
[Errno 2] No such file or
directory:
'/Users/rcline/grassdata/oakesModel/\ngridTest01sql'
Mapset Access fails because the mapset gridTest01sql begins with "\n".
This results because the g.mapsets -l returns multiple lines:
GRASS 6.4.0RC4 (oakesModel):~ > g.mapsets -l
aquiferBnd aquifers boresModel01 boresModel02 drains grid_tran01
grid_tran03
gridTest01sql oakes2 PERMANENT testAreaTopo
In lines 1800-1805 of preferences.py the call to g.mapsets -l is made on
line1800.
ret = gcmd.RunCommand('g.mapsets',
flags = 'l',
read = True)
mapsets = []
if ret:
mapsets = ret.rstrip(' \n').split(' ')
In line 1805, ret.rstrip(' \n').split(' '), only the trailing line feed is
removed and not the line feed following the first line. Line 1805 should
be replaced with:
mapsets = ret.replace('\n','').split()
That way both the last line feed and any line feeds on multiple lines are
removed. Using .split() removes the need to handle the trailing space.
The change fixes the problem for me in 6.4RC4 and 6.4RC5. It also fixed a
crash when starting wxpython and opening an existing workspace. Can
someone with svn access verify my solution and fix this.
When invoking Mapset Access from the TclTK GUI, the search order was the
current mapset, Permanent, other mapsets in alphabetical order. With the
wxpython GUI, the search order is mapsets in alphabetical order. Was this
change intentional? It breaks some of my scripts, as I assumed that the
current mapset would always be searched first.
Royce Cline
Ticket URL: <http://trac.osgeo.org/grass/ticket/630#comment:1>
