[GRASS-dev] Re: [GRASS GIS] #630: "Mapset Access" broken (wxpython)
trac at osgeo.org
Sun Jun 14 15:25:19 EDT 2009
Reporter: cnielsen | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords:
Platform: All | Cpu: Unspecified
Comment (by martinl):
Replying to [comment:1 kyngchaos]:
> ret = gcmd.RunCommand('g.mapsets',
> flags = 'l',
> read = True)
> mapsets = []
> if ret:
> mapsets = ret.rstrip(' \n').split(' ')
> In line 1805, ret.rstrip(' \n').split(' '), only the trailing line feed
is removed and not the line feed following the first line. Line 1805
should be replaced with:
> mapsets = ret.replace('\n','').split()
> That way both the last line feed and any line feeds on multiple lines
are removed. Using .split() removes the need to handle the trailing space.
> The change fixes the problem for me in 6.4RC4 and 6.4RC5. It also fixed
a crash when starting wxpython and opening an existing workspace. Can
someone with svn access verify my solution and fix this.
Fixed in r37880 (devbr6), r37881 (relbr64) and r37882 (trunk).
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/630#comment:3>
