[GRASS-dev] terminology issues in grass7
Maciej Sieczka
msieczka at sieczka.org
Mon Jun 15 15:31:59 EDT 2009
Markus GRASS pisze:
> Maciej Sieczka wrote:
>> GRASS vector layers most of the time have common geometry or
>> "subject", OGR layers not necessarily. E.g. shapefiles in a
>> directory don't need to have anything in common.
> Same for GRASS vector layers, as long as it's in the same projection
> and topology does not interfere. Technically speaking, even two
> polygons in the same shapefile have nothing in common because there
> is no topology and they can not relate to the same entry in an
> attribute table.
>> They are just stored in the same place.
> You could call that messy data management if data that have nothing
> in common are stored in the same place, no offence;-) Just because
> it's technically possible doesn't mean that it makes sense, and GRASS
> is discouraging this although it is to a degree possible. Usually,
> when I get a directory with shapefiles, they are indeed related to
> each other, and if possible I import all of them into one vector as
> different layers.
Yeah well I guess I said all I wanted to. I bet everybody's going to be
glad if I don't interfere anymore :).
Bye!
Maciek
Maciej Sieczka
http://www.sieczka.org
