[GRASS-dev] Re: [GRASS GIS] #648: g.proj fails to create default region using Grass6.4 RC5
Casey Vandenberg casey.vandenberg at sjgeophysics.com
Mon Jun 15 18:16:26 EDT 2009
I have also tried creating a new mapset using g.mapset -c and I get an
error saying the region is invalid, and that g.region needs to be run
manually.
Running g.region manually would not resolve that issue (I had to copy
the WIND file from a different mapset to the new one to get it to
recognize the region settings).
>   Reporter:  voncasec  |       Owner:  grass-dev at lists.osgeo.org
>       Type:  defect    |      Status:  new
>   Priority:  major     |   Milestone:  6.4.0
>  Component:  Python    |     Version:  6.4.0 RCs
> Resolution:            |    Keywords:  g.proj, wxpython, g.region, UTM
>   Platform:  Linux     |         Cpu:  x86-64
> Changes (by LarryS):
>   * keywords:  g.proj, wxpython => g.proj, wxpython, g.region, UTM
>   * priority:  normal => major
>   * component:  wxGUI => Python
>   * summary:  g.proj fails using Grass6.4 RC5 wxpython => g.proj fails to
> Comment:
>  Same issue here on Mac OS X Leopard (10.5.7 - 64 bit) using Kyngesburye
>  frameworks (he does not think it has anything to do with his build, per
>  se).
>  However, all methods of creating any UTM location fail, both GUIs and via
>  command line. DEFAULT-WIND just ends up with 'proj: 1, zone: <zone# here>'
>  without any region specs. I can create a geographic-based location, but
>  any UTM projected locations fail, whether using NAD27 or NAD83 and any
>  datum conversion. Also fails regardless of method of defining the UTM
>  setup, either via EPSG code, PROJ def, etc.
>  Location creation never gets to defining the region (as indicated by
>  previous poster), making an unusable location. I have not tested whether
>  other projections have the same issue.
