[GRASS-dev] Re: [GRASS GIS] #612: g.html2man: parsing leads to man
page errors
trac at osgeo.org
Mon Jun 15 18:58:44 EDT 2009
#612: g.html2man: parsing leads to man page errors
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: Docs | Version: 6.4.0 RCs
Resolution: | Keywords: g.html2man
Platform: Unspecified | Cpu: All
Comment (by glynn):
Replying to [comment:7 hamish]:
> yeah, I look at doing that first. But the <H2>NAME really wasn't
appropriate for the intro and driver custom HTML pages I looked at
I'm not so sure.
> and so I went with the meta-tag solution.
Actual <meta> tags would be a reasonable solution for any files which
genuinely shouldn't have a NAME section, e.g.
<meta name="name" content="grass-dbf" scheme="GRASS">
> I couldn't see how to make that work with the python version (does
HTMLParser.py strip out the comments before we can get our hands on
them?), and so I left it for now.
It's possible to add a handler for comments, but I don't consider this
appropriate.
Comments are comments; you are supposed to be able to use them as you
wish, without any consequences. The only situation where it's appropriate
for an application to take note of comments in its input is if it intends
to include them as comments in its output.
Ticket URL: <https://trac.osgeo.org/grass/ticket/612#comment:8>
