[GRASS-dev] Re: [GRASS GIS] #625: make errors (missing demolocation)
trac at osgeo.org
Tue Jun 16 01:29:13 EDT 2009
Reporter: cnielsen | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: default | Version: svn-trunk
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by glynn):
Replying to [comment:7 hamish]:
> I can reproduce something similar on amd64 Linux with r37899.
> (pretty new Debian/Lenny)
> the problem seems to be that the system type is not detected properly
("unknown" or ""), and build dirs end up called bin./ and dist./.
System detection is up to config.guess; we might need a newer version.
> there is: "config.status.x86_64-unknown-linux-gnu"
Are you sure that this isn't a leftover from a previous build?
> for releasebranch_6_4 on the same machine I get: bin.x86_64-unknown-
linux-gnu/ and dist.x86_64-unknown-linux-gnu/ and it builds ok.
> error is:
ERROR: LOCATION << /usr/src/grass/svn/trunk/dist.unknown/demolocation >>
not available
> in the above note dist. != dist.unknown.
> I had a look but couldn't see where in configure's uname magic it
determines the "unknown" type. Seems to be related to cross-compiling.
# Set ARCH
ARCH=
if test -z "${host}"; then
ARCH="unknown"
else
ARCH="${host}"
fi
Note that Platform.make.in has:
ARCH = @host@
Although configure.in has:
AC_SUBST(ARCH)
ARCH isn't used in Platform.make.
Also, SC_CONFIG_FLAGS uses uname (which means that cross-compiling can't
work), while everything else uses $host.
Which reminds me that SC_CONFIG_FLAGS should have been discarded for 7.0.
Ticket URL: <https://trac.osgeo.org/grass/ticket/625#comment:9>
