[GRASS-dev] Re: [GRASS GIS] #570: startup problem with standalone GRASS install
GRASS GIS trac at osgeo.org
Wed Jun 17 04:20:56 EDT 2009
  Reporter:  timmie        |       Owner:  timmie
      Type:  defect        |      Status:  reopened
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Installation  |     Version:  svn-develbranch6
Resolution:                |    Keywords:
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by hamish):
 Are the GRASS_PYTHON, PATH, and PYTHON_PATH environment variables all set
 to pick up a consistent version of modern python? if grass tries to run
 it's own python.exe but the PATH order grabs the .dll from PythonXY first,
 it's likely you will see errors.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/570#comment:21>
