[GRASS-dev] Re: [GRASS GIS] #570: startup problem with standalone GRASS install
GRASS GIS trac at osgeo.org
Wed Jun 17 07:45:14 EDT 2009
  Reporter:  timmie        |       Owner:  timmie
      Type:  defect        |      Status:  reopened
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Installation  |     Version:  svn-develbranch6
Resolution:                |    Keywords:  wingrass, python
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by hamish):
 Replying to [comment:23 timmie]:
 > Where should  GRASS_PYTHON point to?
 set GRASS_PYTHON=C:\path\to\python.exe
 which should be the version of python which you want GRASS to use and set
 before you try to start GRASS.
 make sure the first path with a python25.dll (or whatever that is called)
 which shows up in your %PATH% matches that.
 i.e. the straight-python bits might not care which flavour of python you
 use as long as the .exe and .dll are matched. But the wxvdigit and wxnviz
 C++ compiled parts will probably want only the exact python(.exe & .dll)
 that they were built for.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/570#comment:27>
