[GRASS-dev] Re: [GRASS GIS] #570: startup problem with standalone
GRASS install
trac at osgeo.org
Wed Jun 17 17:45:49 EDT 2009
#570: startup problem with standalone GRASS install
Reporter: timmie | Owner: timmie
Type: defect | Status: reopened
Priority: normal | Milestone: 6.4.0
Component: Installation | Version: svn-develbranch6
Resolution: | Keywords: wingrass, python
Platform: MSWindows XP | Cpu: x86-32
Comment (by glynn):
Replying to [comment:21 hamish]:
> Are the GRASS_PYTHON, PATH, and PYTHON_PATH environment variables all
set to pick up a consistent version of modern python? if grass tries to
run it's own python.exe but the PATH order grabs the .dll from PythonXY
first, it's likely you will see errors.
Can someone explain the point of GRASS_PYTHON, given that running a .py
script will use the Python interpreter which is set in the registry?
Absent a reasonable explanation, I intend to remove it in 7.0.
Ticket URL: <https://trac.osgeo.org/grass/ticket/570#comment:31>
