[GRASS-dev] lib/init/grass.py r37899
Thu Jun 18 14:19:06 EDT 2009
What is the intent of this change?
--- lib/init/grass.py	(revision 37898)
+++ lib/init/grass.py	(revision 37899)
@@ -591,9 +591,10 @@
     # Check for gui interface
     if grass_gui == "wxpython":
-	call([os.getenv('GRASS_PYTHON'),
-              gfile("etc", "wxpython", "wxgui.py")])
+        subprocess.Popen([os.getenv('GRASS_PYTHON'),
+                          gfile("etc", "wxpython", "wxgui.py")],
+                         stdout=subprocess.PIPE)
Using subprocess.PIPE when nothing can read from the pipe is a bug.
If output should go to the terminal, stdout shouldn't be set. If
output should be discarded, use os.devnull (see check_gui for example
usage).
