[GRASS-dev] compiling today's grass7 trunk: ogr_srs_api.h: No such file or directory
Fri Jun 19 04:12:48 EDT 2009
Moritz Lennert wrote:
> >> Yes, but what I meant is that I don't see where the proj_wrap_c_FLAGS
> >> variable is read.
> > include/Make/Compile.make:
> > $(OBJDIR)/%.o : %.c $(LOCAL_HEADERS) $(EXTRA_HEADERS) $($*_c_FLAGS) | $(OBJDIR)
> > 	$(call compiler_c)
> > $* is the stem, i.e. the part of the name which the % matches, so if
> > the target is $(OBJDIR)/proj_wrap.c, $* is proj_wrap and $*_c_FLAGS is
> > proj_wrap_c_FLAGS.
> Thanks and sorry, should have been able to find this myself...
That's okay; it took me 5 minutes to find it, and I put it there ;)
> > Except ... variables in dependency lines are substituted when the file
> > is read, and proj_wrap_c_FLAGS hasn't been defined at that point. I'll
> > change the compilation rules to move this into the actions.
> > Try r37929; I can't easily test it, as neither PROJ nor GDAL require
> > any -I switches on my system.
> Now it get's further, but fails with apparently the same problem at:
> OBJ.i486-pc-linux-gnu/vector_wrap.o -c vector_wrap.c
> error: ogr_api.h: No such file or directory
Er, right. It's using $(VECT_INC), which is always empty. It should be
using $(VECT_CFLAGS), which contains $(GDALCFLAGS). Try r37944.
