[GRASS-dev] Remaining shell scripts
Glynn Clements
glynn at gclements.plus.com
Fri Jun 19 04:18:17 EDT 2009
The following is a list of remaining shell scripts (or files which
"file" thinks are shell scripts), not including those which are
clearly only used for building or testing:
gui/scripts/d.path.sh
gui/wxpython/scripts/p.cmd
gui/wxpython/scripts/p.db
gui/wxpython/scripts/p.mon
gui/wxpython/scripts/p.rast
gui/wxpython/scripts/p.vect
lib/init/grass-xterm-mac
lib/init/grass.src
lib/init/html_browser_mac.sh
lib/init/init.sh
lib/init/prompt.sh
macosx/app/build_gui_user_menu.sh
macosx/app/build_html_user_index.sh
macosx/app/grass.sh.in
macosx/pkg/resources/postflight.in
raster/r.li/r.li.setup/area_query
raster/r.li/r.li.setup/masked_area_selection
raster/r.li/r.li.setup/r.li.setup
raster/r.li/r.li.setup/r.li.setup.main
raster/r.li/r.li.setup/sample_area_vector.sh
raster/r.li/r.li.setup/square_mouse_selection.sh
raster/r.li/r.li.setup/square_query
scripts/d.out.gpsdrive/d.out.gpsdrive
scripts/d.vect.thematic/d.vect.thematic
scripts/r.mapcalculator/r.mapcalculator
scripts/r3.mapcalculator/r3.mapcalculator
scripts/v.in.garmin/v.in.garmin
scripts/v.in.gpsbabel/v.in.gpsbabel
scripts/v.out.gps/v.out.gps
visualization/nviz/scripts/nviz
Which ones need to be ported to Python, which ones can be removed,
which ones should stay (with reasons)?
