[GRASS-dev] Remaining shell scripts
Hamish
hamish_b at yahoo.com
Fri Jun 19 05:19:20 EDT 2009
Glynn wrote:
> The following is a list of remaining shell scripts (or files which
> "file" thinks are shell scripts), not including those which are
> clearly only used for building or testing:
> gui/scripts/d.path.sh
wrapper script for d.path so that source vector network map (eg roads) is
drawn in background with d.vect.
d.path only draws the shortest path + start/end points. Not sure how
the wx GUI deals with this-- d.path /was/ an interactive xmon module
but I added a coor= option so now it will run non-interactively if you
specify the start/end coords from the command line. The GUI should collect
those points from two mouse clicks and feed the result to the module
which then generates the render-layer for overlay the Map Display.
> gui/wxpython/scripts/p.cmd
> gui/wxpython/scripts/p.db
> gui/wxpython/scripts/p.mon
> gui/wxpython/scripts/p.rast
> gui/wxpython/scripts/p.vect
IIUC the idea there was to simulate d.* command line tools from the Cmd>
GUI command prompt ???
> scripts/d.out.gpsdrive/d.out.gpsdrive
this is very much like d.out.file in GRASS 6, but it forces window size
to 1280x1024 and writes georef info to a tile index file for the GpsDrive
software's backdrop tiles (www.gpsdrive.de). Requires the PNG driver etc
so won't work with GRASS 7 without a complete change of method. No idea
how to do that, but it is a useful module for users of GpsDrive + GRASS,
so if there is a way to get it to work with gr7, I'd be keen to see it
ported.
If a method is found, it would be nice to recreate a d.out.file too, as
that is very useful.
> scripts/v.in.garmin/v.in.garmin
probably drop this in favour of v.in.gps(babel)
> scripts/v.in.gpsbabel/v.in.gpsbabel
to be compltely rewritten as v.in.gps.py using GpsBabel -> GPX format
then -> the new v.in.ogr GPX driver.
> scripts/v.out.gps/v.out.gps
to be ported.
> visualization/nviz/scripts/nviz
unused? (or if used, just a 1-liner)
note nviz from File menu in wxGUI on WinGrass currently fails for
unknown reasons. ("process complete: 0 sec")
Hamish
