[GRASS-dev] [GRASS GIS] #656: d.out.file fails to create PDF output
on OSX
trac at osgeo.org
Fri Jun 19 17:06:28 EDT 2009
#656: d.out.file fails to create PDF output on OSX
Reporter: sorokine | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Display | Version: 6.4.0 RCs
Keywords: | Platform: MacOSX
Cpu: OSX/Intel |
d.out.file fails to create PDF output on OSX, some libraries missing
d.out.file output=test format=pdf
Using the Cairo driver.
Saving display from Monitor: [x0] to <test.pdf>.
Image size [640 x 480]
dyld: Library not loaded: /Users/Shared/unix/cairo-
leo/lib/libcairo.2.dylib
Referenced from:
/Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_cairodriver.dylib
Reason: image not found
WARNING: No socket to connect to for monitor <cairo>.
WARNING: No such monitor as <cairo>
Screen export complete. (writing the file may take a small amount of time)
Image crop [640 x 320]
Done.
Ticket URL: <http://trac.osgeo.org/grass/ticket/656>
