[GRASS-dev] Re: Raster lib in GRASS7
Hamish hamish_b at yahoo.com
Sun Jun 21 23:04:04 EDT 2009
Glynn wrote:
> AFAICT, there are two options:
> 1. The current region belongs to libraster; in which case,
> G__ belongs in libraster, along with anything which uses it.
> 2. The current region belongs to libgis; in which case, G__
> needs to have the window and window_set fields moved back to
> libgis, and everything which uses the remaining fields needs
> to be moved to libraster.
for my 2c the region belongs to libgis, as it is also used for
display bounds and by region cropping input=/output= flags for
some vector modules.
Hamish
