[GRASS-dev] Re: [GRASS-user] grass 6.4 rc5 and python scripting
Glynn Clements
glynn at gclements.plus.com
Tue Jun 30 12:14:23 EDT 2009
Glynn Clements wrote:
> > In order for g.parser to work, the file teste.py needs to be in your
> > PATH.
> This is actually a bug in G_parser() and G_gui(). menuform.py is being
> passed the base filename rather than the complete path. There isn't
> any other reason why the script needs to be in the path.
I've fixed this in 7.x with r38126. However, menuform.py still tries
to run the script using its basename.
