[GRASS-dev] problem with sql query
Dylan Beaudette
debeaudette at ucdavis.edu
Tue Jun 30 13:09:10 EDT 2009
On Tuesday 30 June 2009, Quentin Page wrote:
> I try to interview two vectors with tables with SQL query.
> when I write :
> echo "update table table1 set attribute1 = 1 where table1.attribute2 =
> table2.attribute2" |db.execute
> I receive an error message. Is there a syntax error with the point
> between tables and attributes?
> Any idea? Can I use sql query to interview two tables in the
> same time?
What is the database back-end? As far as I know, you cannot use update
statements like this with the DBF back-end.
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
