[GRASS-dev] Re: [GRASS GIS] #431: vector operations crash in
64bit OSX
William Kyngesburye
woklist at kyngchaos.com
Sun Mar 1 23:29:58 EST 2009
On Feb 28, 2009, at 10:29 PM, William Kyngesburye wrote:
> On Feb 28, 2009, at 9:43 PM, Michael Barton wrote:
>>> #431: vector operations crash in 64bit OSX
>>> Changes (by mmetz):
>>> * status: new => closed
>>> * resolution: => fixed
>>> Comment:
>>> fixed in trunk r36003 and devbr6 r36049
>>> Ticket URL: <http://trac.osgeo.org/grass/ticket/431#comment:1>
>>> GRASS GIS <http://grass.osgeo.org>
>> Does this mean that we can compile GRASS 7 in 64bit on the Mac now?
> I hope so. I'll be checking it out some time in the next couple
> days. Though we'll have to think about the python stuff now - it
> can't compile 64bits (a limit of wxpython) so adding -arch flags to
> CFLAGS will cause problems. I had worked out a way to strip out
> 64bit flags a while back, I'll dig that up.
Yay! No crash in 64bits (tested dev6, trunk should be OK).
I updated the wx nviz and vdigit makefiles so that any 64bit arch
flags are stripped out and they will be compiled 32bit. At some
point, when wxpython stops using Carbon and can be built 64bit, we'll
have to conditionalize that stripping on the wx version.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed
robot?
[Marvin] You think you have problems? What are you supposed to do if
you ARE a maniacally depressed robot? No, don't try and answer, I'm
50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
