[GRASS-dev] Re: [GRASS GIS] #111: r.los fails in WinGRASS with high values for max_dis parameter
GRASS GIS trac at osgeo.org
Mon Mar 2 10:11:42 EST 2009
  Reporter:  gsancho       |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  major         |   Milestone:  6.4.0
 Component:  Raster        |     Version:  svn-develbranch6
Resolution:                |    Keywords:  wingrass r.los
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by neteler):
 Compiling the updated code with
 MYCFLAGS="-g -Wall  -fno-common"
 MYCXXFLAGS="-g -Wall"
 MYLDFLAGS="-Wl,--no-undefined"
 LDFLAGS="$MYLDFLAGS" CFLAGS="$MYCFLAGS" CXXFLAGS="$MYCXXFLAGS" ./configure
 leads to this problem:
 gcc -L/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/lib -Wl,--no-
 undefined -Wl,--export-dynamic
 -L/usr/lib64 -Wl,-rpath-link,/home/neteler/grass64/dist.x86_64-unknown-
 linux-gnu/lib    -o /home/neteler/grass64/dist.x86_64-unknown-linux-
 gnu/bin/r.los OBJ.x86_64-unknown-linux-gnu/color_rnge.o
 OBJ.x86_64-unknown-linux-gnu/delete.o OBJ.x86_64-unknown-linux-gnu/main.o
 OBJ.x86_64-unknown-linux-gnu/make_list.o OBJ.x86_64-unknown-linux-
 gnu/make_point.o OBJ.x86_64-unknown-linux-gnu/mark_pts.o OBJ.x86_64-
 unknown-linux-gnu/pts_elim.o
 OBJ.x86_64-unknown-linux-gnu/segment.o  -lgrass_segment
 -lgrass_gis -lgrass_datetime -lz      -lgrass_gproj -lgrass_gis
 -lgrass_datetime -lz     -lproj  -L/usr/local/lib -lgdal  -lgrass_gis
 -lgrass_datetime -lz     -lm  -lz
 OBJ.x86_64-unknown-linux-gnu/main.o: In function `main':
 /home/neteler/grass64/raster/r.los/main.c:60: multiple definition of
 `DELAYED_DELETE'
 gnu/delete.o:/home/neteler/grass64/raster/r.los/delete.c:26: first defined
 here
 OBJ.x86_64-unknown-linux-gnu/make_list.o: In function `make_list':
 /home/neteler/grass64/raster/r.los/make_list.c:24: multiple definition of
 `DELAYED_DELETE'
 here
 OBJ.x86_64-unknown-linux-gnu/mark_pts.o: In function
 `mark_visible_points':
 /home/neteler/grass64/raster/r.los/mark_pts.c:24: multiple definition of
 `DELAYED_DELETE'
 here
 OBJ.x86_64-unknown-linux-gnu/pts_elim.o: In function
 `hidden_point_elimination':
 /home/neteler/grass64/raster/r.los/pts_elim.c:53: multiple definition of
 `DELAYED_DELETE'
 here
 OBJ.x86_64-unknown-linux-gnu/segment.o: In function `segment':
 /home/neteler/grass64/raster/r.los/segment.c:24: multiple definition of
 `DELAYED_DELETE'
 here
 collect2: ld returned 1 exit status
 make: *** [/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/bin/r.los]
 Error 1
 Attached patch cures it. Ok to submit?
 Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/111#comment:11>
