[GRASS-dev] Compile errors - dllmain and fmode - releasebranch_6_4
and develbranch_6
Colin Nielsen
colin.nielsen at gmail.com
Mon Mar 2 10:29:24 EST 2009
Lots of compile errors on make on my vista machine (using mingw/msys
not osgeo4w). This is the first one, from lib/datetime:
gcc -shared -o /usr/local/src/grass-6.4_release/dist.i686-pc-mingw32/lib/libgrass_datetime.6.4.0svn.dll
-L/usr/local/src/grass-6.4_release/dist.i686-pc-mingw32/lib
-Wl,--export-dynamic,--enable-runtime-pseudo-reloc -L/usr/local/lib
-L/usr/local/pgsql/lib OBJ.i686-pc-mingw32/between.o
OBJ.i686-pc-mingw32/copy.o OBJ.i686-pc-mingw32/same.o
OBJ.i686-pc-mingw32/diff.o OBJ.i686-pc-mingw32/error.o
OBJ.i686-pc-mingw32/format.o OBJ.i686-pc-mingw32/incr1.o
OBJ.i686-pc-mingw32/incr2.o OBJ.i686-pc-mingw32/incr3.o
OBJ.i686-pc-mingw32/local.o OBJ.i686-pc-mingw32/misc.o
OBJ.i686-pc-mingw32/change.o OBJ.i686-pc-mingw32/scan.o
OBJ.i686-pc-mingw32/sign.o OBJ.i686-pc-mingw32/type.o
OBJ.i686-pc-mingw32/tz1.o OBJ.i686-pc-mingw32/tz2.o
OBJ.i686-pc-mingw32/values.o
../../lib/gis/OBJ.i686-pc-mingw32/dllmain.o && \
(cd /usr/local/src/grass-6.4_release/dist.i686-pc-mingw32/lib;
ln -f -s libgrass_datetime.6.4.0svn.dll
/usr/local/src/grass-6.4_release/dist.i686-pc-mingw32/lib/libgrass_datetime.dll)
gcc.exe: ../../lib/gis/OBJ.i686-pc-mingw32/dllmain.o: No such file or directory
make: *** [/usr/local/src/grass-6.4_release/dist.i686-pc-mingw32/lib/libgrass_datetime.6.4.0svn.dll]
Error 1
and from lib/gis:
make: *** No rule to make target
`../../lib/gis/OBJ.i686-pc-mingw32/dllmain.o', needed by `default'.
Stop.
The errors seem to be related to the dllmain and fmode problems from
ticket #469 <http://trac.osgeo.org/grass/ticket/469>, but they seem to
affect only the versions post-fix. While releasebranch_6_4 and
develbranch_6 have make errors, releasebranch_6_3 doesn't have these
errors.
Thanks,
-Colin
