[GRASS-dev] Re: [GRASS GIS] #111: r.los fails in WinGRASS with high
values for max_dis parameter
trac at osgeo.org
Mon Mar 2 11:38:38 EST 2009
#111: r.los fails in WinGRASS with high values for max_dis parameter
Reporter: gsancho | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: svn-develbranch6
Resolution: | Keywords: wingrass r.los
Platform: MSWindows XP | Cpu: x86-32
Comment (by neteler):
It crashes Linux (I have a 64bit box, using latest version of r.los):
GRASS 6.5.svn (patUTM32): > r.los pat_dtm_5m out=lavarone_viewshed_los
coordinate=676769.91,5091720.66 obs_elev=42 max=30000
Using maximum distance from the viewing point (meters): 30000.000000
18%
Segmentation fault
GRASS 6.5.svn (patUTM32): > g.region -p
projection: 1 (UTM)
zone: 32
datum: wgs84
ellipsoid: wgs84
north: 5103410
south: 5084090
west: 653990
east: 684010
nsres: 10
ewres: 10
rows: 1932
cols: 3002
cells: 5799864
will post a gdb bt.
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/111#comment:12>
