[GRASS-dev] Re: [GRASS GIS] #399: Added "backlink" functionality to
r.walk, r.cost & r.drain
trac at osgeo.org
Wed Mar 4 07:32:14 EST 2009
#399: Added "backlink" functionality to r.walk, r.cost & r.drain
Reporter: cnielsen | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: unspecified
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by neteler):
Replying to [comment:12 cmbarton]:
> The r.drain patch doesn't compile. Error below
> Michael
> cmb-MBP-2:r.drain cmbarton$ patch -p0 < 6devdrain.patchpatching file
main.c
> patching file description.html
> cmb-MBP-2:r.drain cmbarton$ make
> gcc -I/Users/cmbarton/grass_dev/grass6_src/dist.i386-apple-
darwin9.6.0/include -arch i386 -Os
-I/Library/Frameworks/GDAL.framework/Versions/1.6/Headers
-DPACKAGE=\""grassmods"\" -I/Users/cmbarton/grass_dev/grass6_src/dist.
i386-apple-darwin9.6.0/include -o OBJ.i386-apple-darwin9.6.0/main.o -c
main.c
> main.c: In function ‘main’:
> main.c:608: error: too many arguments to function ‘Vect_build’
> make: *** [OBJ.i386-apple-darwin9.6.0/main.o] Error 1
The newer prototype is (only one argument, delete the second):
int Vect_build(struct Map_info *Map)
This indicates that the patch was prepared with an older GRASS version.
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/399#comment:14>
