[GRASS-dev] Compile errors - dllmain and fmode -
releasebranch_6_4 and develbranch_6
Glynn Clements
glynn at gclements.plus.com
Wed Mar 4 11:47:45 EST 2009
Markus Neteler wrote:
> >> >> The fixes were
> >> >> - 6.4.svn (r35767, r35769)
> >> >> - 6.4.0svn (r35768, r35770)
> >> >> > [Probably because a complete fix doesn't exist; the change implies
> >> >> > that dllmain.c would be part of lib/gis, but lib/datetime is built
> >> >> > first.]
> >> >> What is exactly missing?
> >> > dllmain.c.
> >> > But hang on: DLLMAIN_OBJ doesn't appear to be defined anywhere in
> >> > develbranch_6.
> >> I seem to have a different version:
> > Er, right; my Shlib.make was modified to remove the DLLMAIN_OBJ stuff
> > (probably to get it to compile).
Actually, that's probably not it. But for whatever reason, I have a
modified version without the changes.
> On which platform did it fail?
It will fail on MinGW, as the changes add dllmain.o to the link
command but don't provide any way for that file to be created.
