sqlite and grass65: was Re: [GRASS-dev] sqlite and grass64
Moritz Lennert mlennert at club.worldonline.be
Fri Mar 6 02:59:41 EST 2009
On 06/03/09 01:24, Moskovitz, Bob wrote:
>>> Concerning the need to be able to easily backup/share, I
>> think we definitely
>>> need some module which isolates and exports a series of
>> chosen maps in a new
>>> temporary mapset with a local sqlite db file, copies the
>> chosen maps into
>>> this temp mapset and then creates a tarball (or zip or
>> whatever) with the
>>> basic LOCATION info (i.e. a PERMANENT mapset with PROJ and
>> WIND files) and
>>> the temp mapset. Shouldn't be too hard to wip up, or ?
>> Essentially a v.pack/v.unpack, right?
>> Markus
> What would be really neat is if there was a way to delete, as well as archive a location from the startup screen.
That should actually be much easier. Deleting just implies removing the
directory from the file system, archiving just needs a call to create a
tar ball or equivalent. So, essentially a small GUI to call one single
command.
v.pack/v.unpack would be different in that it should deal with
individual maps. even though I suggest to include the location info as
sort of meta-data, but also to give the possibility to v.unpack into a
new, stand-alone location. Don't know if the last is really necessary,
though. Just including necessary meta-data concerning the projection
system should be enough.
Moritz
> Bob
