[GRASS-dev] libgis: ERROR: Unable to make mapset element cell_misc/...
Markus Neteler neteler at osgeo.org
Sat Mar 7 02:01:47 EST 2009
On Sat, Mar 7, 2009 at 6:34 AM, Glynn Clements <glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
> access() sets errno when it fails.
> If you want the reason why mkdir() failed, you need to test the return
> value from G_mkdir(), e.g.:
>        if (access(path, 0) != 0)
>            if (G_mkdir(path) != 0)
>                G_fatal_error(_("Unable to make mapset element %s (%s): %s"),
>                                p_element, path, strerror(errno));
Ah thanks. I see now that access() is used twice:
http://trac.osgeo.org/grass/browser/grass/trunk/lib/gis/mapset_msc.c#L57
I assume that I can remove the first try? see attached patch.
Or is a second try to access unavoidable?
Markus
Markus
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20090307/724ee026/mapset_msc.obj
