[GRASS-dev] location wizard borked
Michael Barton michael.barton at asu.edu
Tue Mar 10 11:32:12 EDT 2009
On Mar 10, 2009, at 5:50 AM, <grass-dev-request at lists.osgeo.org> wrote:
> Date: Tue, 10 Mar 2009 11:54:50 +0100
> From: Martin Landa <landa.martin at gmail.com>
> Subject: Re: [GRASS-dev] location wizard borked
> To: Vincent Bain <bain at toraval.fr>
> Cc: grass-dev <grass-dev at lists.osgeo.org>
> Message-ID:
> 	<f8fe65c40903100354y2d6cfdaanb70b663e639347cc at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> Hi,
> 2009/3/10 Vincent Bain <bain at toraval.fr>:
>> related to the location wizard, perhaps what follows does not deal
>> with
>> any sort of bug but my misuse of the location creation process :
>> If you need to create from scratch a new gisdabe, located elsewhere
>> than
>> the current one, the location wizard first writes your new location
>> directory in the /current/ gisdbase instead of the new one you've
>> just
>> set. Then when you define a new mapset or want to start from within
>> PERMANENT, the application fails, with this message :
> seems to work for me.
> 1. Create new directory for gisdbase (e.g. $HOME/grassdata1) - mkdir
> 2. Choose gisdbase
> 3. Run location wizard
> 4. New location created in $HOME/grassdata1
> Martin
I can confirm this. Regardless of whether you browse to a new
directory in the startup screen or put in a new gisdbase directory in
the location wizard, it only makes a location in the "current" gisdbase.
Michael
