[GRASS-dev] v.type.sh question - important for 6.4 release
Michael Barton
michael.barton at asu.edu
Thu Mar 12 12:41:48 EDT 2009
On Mar 11, 2009, at 12:10 PM, Glynn Clements wrote:
>>> The way that we normally make shell scripts work on Windows is to
>>> provide a .bat file which explicitly invokes the script via
>>> $GRASS_SH.
>>> On Windows, the $GISBASE/bin directory will contain a .bat file for
>>> each script in the $GISBASE/scripts directory. These are created
>>> using
>>> the scripts/windows_launch.bat file as a template.
>>> It may suffice to add $GISBASE/etc/gui/scripts/v.type.sh.bat. If
>>> that
>>> doesn't work, add an "if windows ..." case to gis.m's "execute"
>>> function, which invokes the script via $env(GRASS_SH).
>>> Glynn Clements <glynn at gclements.plus.com>
>> This sounds good. Two questions.
>> 1) How can we get the *.bat files to be generated for files in the
>> $GISBASE/ext/gui/scripts folder?
> For the scripts in the scripts directory, this is done via the
> following rule from Script.make:
> $(BIN)/$(PGM).bat: $(MODULE_TOPDIR)/scripts/windows_launch.bat
> sed -e "s#SCRIPT_NAME#$(PGM)#" $(MODULE_TOPDIR)/scripts/
> windows_launch.bat > $@
> For the gui/scripts, the above rule can be generalised to a pattern
> rule:
> $(GISBASE)/etc/gui/scripts/%.bat: $(MODULE_TOPDIR)/scripts/
> windows_launch.bat
> sed -e "s#SCRIPT_NAME#$*#" $(MODULE_TOPDIR)/scripts/
> You then need to "make" the relevant .bat files with e.g.:
> for file in *.* ; do $(MAKE) $(GISBASE)/etc/gui/scripts/$
> $file.bat ; done
>> 2) Can v.type.sh.bat be called by just specifying v.type.sh? Or do
>> you
>> need to fully specify the *.bat extension?
> Just using the base name seems to work for everything else, although I
> can't exclude the possibility that Tcl behaves differently depending
> upon whether a full path is used (it's actually Tcl which tries the
> .exe and .bat suffixes; it doesn't use Windows' ShellExecute()).
If someone who knows the build system well can make the changes Glynn
recommended to Script.make, we can test to see if that does the trick.
If not, I can change try to conditionalize the TclTk call for windows
to find v.type.sh.bat.
(related question, is such a name permitted for Windows XP and Vista?)
Michael
