[GRASS-dev] Re: [GRASS-SVN] r36342 - grass/trunk/raster/r.los
Glynn Clements
glynn at gclements.plus.com
Fri Mar 13 07:10:28 EDT 2009
Markus Neteler wrote:
> > Author: glynn
> > Date: 2009-03-12 07:33:40 -0400 (Thu, 12 Mar 2009)
> > New Revision: 36342
> > Modified:
> > grass/trunk/raster/r.los/main.c
> > grass/trunk/raster/r.los/point.h
> > Log:
> > Fix compilation error due to r36161/r36181; 7.0 doesn't abuse the preprocessor
> A backport candidate?
There was a large change which removed all of the "#ifdef MAIN" usage
in 7.0. If you aren't going to backport all of it, there probably
isn't much point doing isolated cases.
