[GRASS-dev] Re: [GRASS GIS] #523: wxGUI: querying a vector map in edit mode does nothing
GRASS GIS trac at osgeo.org
Fri Mar 13 13:00:29 EDT 2009
  Reporter:  msieczka  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  major     |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Comment (by hellik):
 Replying to [comment:1 martinl]:
 > Seems to work for me. Can you post NC-based example?
 > Martin
 grass64rc3-3 (osgeo4w) - win vista
 data nc-spm
     g.copy vect=lakes at PERMANENT,test
 loading test in wx-gis-map-display
 querying test map in edit mode => window for update attributes pop up
 but submit a change for example in the field "FTYPE" (character) from
 RESERVOIR to DAM
 then following error message:
   File "C:\OSGeo4W\apps\grass\grass-6.4.0RC3\etc\wxpython\gu
 i_modules\dbm.py", line 3101, in OnSubmit
 "input=%s" % sqlFile.name])
 i_modules\gcmd.py", line 355, in __init__
 _("Error: ") + self.GetError()))
 gui_modules.gcmd
 CmdError
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/523#comment:2>
