[GRASS-dev] Re: [GRASS GIS] #536: memory corruption
trac at osgeo.org
Sun Mar 22 12:12:47 EDT 2009
Reporter: martinl | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords:
Platform: Linux | Cpu: x86-32
Comment (by martinl):
Replying to [comment:7 mmetz]:
> Is this only true for vector bs or for all vectors?
No, for all vectors.
> What are the contents of vector/bs/head, is there something specified
for OTHER INFO:?
empty string
> I suspect Vect__read_head because according to the description of this
ticket, something is wrong with setting Map->head.line_3 within
Vect__read_head, and Vect__read_head reads the plain text file named head.
When leaving Vect_open_old_head everything seems OK.
Vect_open_old_head (Map=0xbffef630, name=0x8b200f0 "bs", mapset=0x804aea8
"") at open.c:474
(gdb) n
(gdb) p Map->head.line_3
$7 = 0x8b206e0 ""
Next step -> memory corrupted
(gdb) n
main (argc=2, argv=0xbffefb84) at main.c:110
$8 = 0x7b1ea71 <Address 0x7b1ea71 out of bounds>
Sorry, no idea...
Ticket URL: <http://trac.osgeo.org/grass/ticket/536#comment:8>
