[GRASS-dev] Re: [GRASS GIS] #537: g.proj.exe crashes on Windows
Vista (osgeo4w)
trac at osgeo.org
Mon Mar 23 09:39:50 EDT 2009
#537: g.proj.exe crashes on Windows Vista (osgeo4w)
Reporter: giohappy | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Resolution: | Keywords: osgeo4w g.proj gdal
Platform: MSWindows Vista | Cpu: x86-32
Comment (by giohappy):
I'm sorry. I missed the explanation. It has been PARTLY solved with the
attached patches my Jef. It's a problem with memory release.
I would keep it open because other tests reveal a strange problem. While
the creation of projections has been solved, the proj output as wkt still
causes a crash for certain projections. It works fine if I use a loc,
i.e., from epsg 3004, while it crashed with epsg 4326 or epsg 32632.
I will investigate more.
I hope this kind of memory deallocation problems don't propagate to other
parts of Grass!
Ticket URL: <http://trac.osgeo.org/grass/ticket/537#comment:6>
