[GRASS-dev] Re: [GRASS GIS] #96: v.surf.bspline broken
trac at osgeo.org
Mon Mar 23 11:04:14 EDT 2009
Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.0
Component: Raster | Version: unspecified
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by neteler):
I found suspicious code which was introduced in the last fix round.
Commenting that out attributes are taken again. I don't understand the
purpose of the part which I have commented in attached patch
v.surf.bspline_fix_attribs.diff. AFAIK "type" is defined but not set.
There is another "type" in main() - perhaps a different variable was
supposed to be used to test against GV_POINTS?
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/96#comment:7>
