[GRASS-dev] Re: [GRASS GIS] #96: v.surf.bspline broken
GRASS GIS trac at osgeo.org
Mon Mar 23 16:06:41 EDT 2009
  Reporter:  cmbarton  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  reopened
  Priority:  major     |   Milestone:  6.4.0
 Component:  Raster    |     Version:  unspecified
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Comment (by marisn):
 Replying to [comment:7 neteler]:
 > I found suspicious code which was introduced in the last fix round.
 Commenting that out attributes are taken again. I don't understand the
 purpose of the part which I have commented in attached patch
 v.surf.bspline_fix_attribs.diff. AFAIK "type" is defined but not set.
 There is another "type" in main() - perhaps a different variable was
 supposed to be used to test against GV_POINTS?
 > Markus
 Original code (almost) makes sense (r21982).
 /*type = Vect_read_line (&In, points, Cats, observ[i].lineID);*/
 if ( !(type & GV_POINTS ) ) continue;
 Still I have no idea how to fix this module (I'm lazy) (fix == does it
 needs that check or not). Also I looked at P_Read_Vector_Region_Map
 (lidarlib/zones.c) and it seemed somehow fishy - it reads vector line and
 then uses only first coordinate of that line, still as code lacks any
 comments about it's design specifics (and it has them i.e. as it crunches
 over all vector lines on every function call instad of using standart V_*
 functions) I can only suggest to somebody who understands that code to add
 comments and, probably, line type check.
Ticket URL: <http://trac.osgeo.org/grass/ticket/96#comment:9>
