[GRASS-dev] db.connect
Marco Lechner - FOSSGIS e.V. marco.lechner at fossgis.de
Wed Mar 25 11:44:00 EDT 2009
may be he is using the GRASS Toolbox in QGIS:
some GRASS modules are divided in multiple "modules" with different
fixed default values using the GRASS toolbox available through QGIS. So
is db.connect
Marco
Moritz Lennert schrieb:
> On 24/03/09 10:46, Paolo Cavallini wrote:
>> Hi all.
>> Sorry about my ignorance. I do not understand why having both db.connect
>> and db.connect.schema (the second is == to the first, with just one
>> extra option).
> Where do you see a db.connect.schema ? db.connect has a schema option.
> Moritz
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
