[GRASS-dev] Re: [GRASS-windows] windows qgis-grass: make grass build with vc or keep a separate qgis-grass mingw build?
Markus Neteler neteler at osgeo.org
Fri Mar 27 10:17:36 EDT 2009
On Fri, Mar 27, 2009 at 3:05 PM, G. Allegri <giohappy at gmail.com> wrote:
> Thanks Jef. So, fixing the memory issues in grass code isn't
> avoidable.
I think that several developer are willing to help here once understood
the problems which means...
> I'll go on with this (after g.proj, db binaries, v.in.ogr, etc.),
... cycle through all these problems and fix one after the other.
g.proj is already done thanks to Paul.
Please send a concrete list, ideally with debug output.
Markus
