[GRASS-dev] georect.py
Martin Landa
landa.martin at gmail.com
Sat Mar 28 09:29:58 EDT 2009
2009/3/28 Vincent Bain <bain at toraval.fr>:
> pdctype='text', coords=coord)
> File "/usr/local/grass-6.5.svn/etc/wxpython/gui_modules/ma
> pdisp_window.py", line 366, in Draw
try to put before this line
print type(coords[0]), type(coords[1])
<type 'int'> <type 'int'> should be printed.
> pdc.DrawText(img['text'], coords[0], coords[1])
> File "/usr/local/grass-6.5.svn/etc/wxpython/vdigit/grass6_
> wxvdigit.py", line 372, in DrawText
> def DrawText(*args): return
> _grass6_wxvdigit.PseudoDC_DrawText(*args)
> TypeError
> in method 'PseudoDC_DrawText', argument 3 of type 'int'
> Could the source of this problem be my configuration of wxpython ? (no
> errors detected at compilation)
It's related to the local copy of PseudoDC from vdigit. BTW, which
version of swig are you using?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
