[GRASS-dev] georect.py
Martin Landa landa.martin at gmail.com
Sat Mar 28 10:55:36 EDT 2009
2009/3/28 Vincent Bain <bain at toraval.fr>:
> Le samedi 28 mars 2009 à 14:29 +0100, Martin Landa a écrit :
>> try to put before this line
>> print type(coords[0]), type(coords[1])
>> <type 'int'> <type 'int'> should be printed.
> modified the file the way you suggest, but the command now returns <type
> 'float'> <type 'float'> instead.
>> It's related to the local copy of PseudoDC from vdigit. BTW, which
>> version of swig are you using?
Hopefully fixed in r36503.
M.
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
